Old 12-18-2020, 01:48 PM   #1
Brad Hawk
Liked 2 Times in 1 Post
Default Leaf springs & CalTracs separation
I'm interested in people's feedback on how they've set up their leaf spring suspension when using CalTracs, Assassin Bars, etc. w/ respect to promoting vs restricting chassis separation.
My original understanding was using these "devices" allowed for more control of the rear suspension on launch w/o having to rely on a large amount of chassis separation as was expected (required?) w/ Super Stock springs, Try-City Launchers, "slapper" bars.
However, I'm seeing plenty of Stockers w/ CalTracs & Assasins where there still appears to be significant amount of separation happening. I'm wondering if it's an "it depends..." thing, whether certain chassis combinations (like my Mopar E-body) respond better to this approach, or what other factors may need to be taken into account (leaf spring lengths before & after axle? weight distribution? ...?).
For reference, here is the data from a series of passes made before I pulled apart the car (quite a ways back, unfortunately). The CalTracs & split mono-leaf springs were strapped down a good bit w/ the old Ranchos on setting 4 of 5, so there was minimal separation. The front suspension was very loose (possibly too loose) w/ 5-1/4" extension from static ride height. Unfortunately, no good pics or videos to go w/ the data.
Also, in case the 60-fts look "slow", it's cuz this is a street/strip car w/ only a 4500-flash converter, 4.10s, and 9" DOT drag radials. Welcome to my build of compromises...
- 60 - / 660 / MPH / 1320 / MPH / Weather conditions
1.459 / 6.682 / 101.66 / 10.566 / 126.01 / < No weather #s >
1.468 / 6.677 / 101.87 / 10.561 / 126.00 / 74*, 48%, 30.57"
1.463 / 6.698 / 101.45 / 10.582 / 126.18 / 65*, 42%, 30.38"
1.464 / 6.682 / 101.71 / 10.563 / 126.12 / 72*, 33%, 30.35"
1.459 / 6.681 / 101.47 / 10.570 / 125.97 / 73*, 33*, 30.33"
Not asking for "trade secrets", but some feedback would be appreciated. Thx!
Brad Hawk is offline   Reply With Quote
Old 12-18-2020, 03:47 PM   #2
GTX JOHN
Liked 2,492 Times in 700 Posts
Default Re: Leaf springs & CalTracs separation
I run Ranchos with Caltracs on same settings
Not a bunch of separation but 1.3s in 60fts. on our 340
Stockers.
Very Consistent and well pleased with John Calvert's stuff!!!
John Irving
741 Stock
741 Super Stock
Old 12-18-2020, 04:35 PM   #3
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
I have not raced in a while. But it used to be that as I improved my 60 foot time my 1/4 et improved. It seems as your 60 foot times get worse you et gets better.
Stan
- 60 - / 660 /// MPH /// 1320 //// MPH /// Weather conditions
Old 12-18-2020, 05:00 PM   #4
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
You will need a good pair of rear shocks too control the separation. I use Afco double adjustable shocks on the rear of my 67 Camaro which has Caltrac's bars and split mono leaf springs. I tried Competition Engineering 3 way adjustable shocks and QA1 double adjustable shocks. Neither one of these shocks are strong enough to slow down the body separation when using the Caltrac bars. My car 60ft 1.35-1.37 When I brought my car to Mark Markow for some suspension work, he is the one that recommended the Afco shocks. I had just bought a brand new pair of QA1's right before I brought the car to him. Even though they were brand new, he told me they wouldn't be strong enough to handle the pressure from the Caltrac bars. Car hooks hard now.
NHRA1926 is offline   Reply With Quote
Old 12-18-2020, 05:29 PM   #5
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I always assumed separation was somewhat the point of the CalTracs. They convert the rotational force of the rear housing trying to "wrap" into a downward force on the front of the spring, causing it to arch and lift the body.
S/ST 51
S/C 53
Old 12-18-2020, 07:05 PM   #6
Frank Castros
Liked 2,755 Times in 975 Posts
Ask Pete Lanciers.
