Liked 502 Times in 130 Posts
Test Pig:
The mighty Gremllin, currently running Amalie Type F, which per their spec sheet says is 10-20 weight. Per the chasis dyno wants 500 looser on the RPM, which is obviously a ton, and not going to happen with just fluid, but with a low HP beast like the Gremlin, we might see more of an effect of the fluid than say your standard 635 HP 396 stocker....... Reflashing this convertor, too risky. Have a known good enough thing here. I know just about all the info on the site is about using thicker fluid to lower stall, I'm looking to increase stall as much as possible. I believe specific gravity is likely the ultimate factor in stall, So for my type F, using the formula, 141.5/API of 31.5 plus 131.5=.8498 a thinner fluid like their Dexron VI syntethetic with a API of 35 would be a .8681 SG This is 1.0215% thinner than the type F. The ATI 0w-8 weight might be a option, I know there are other synthetic fluids out there with real thin weights. Eric
Eric Merryfield 1883 STK |
#2 | |
Liked 1,583 Times in 582 Posts
I have been researching this along with engine oil. I have been focused on viscosity index and kinematic visosity in cSt at 104 degrees F and 212 degrees F. Most manufacturers have data sheets. I haven't been paying much attention to the spec gravity but I will now. ATI Super F 20wt is lighter than Amalie Type F by a few numbers. Red Line makes a lightweight racing ATF that is much lighter than both of them. ATI makes 8wt but can't find numbers on it.
Liked 971 Times in 308 Posts
Buy another convertor that is looser
Liked 2,484 Times in 697 Posts
We routinely adjust Convertor stalls without problems
Liked 320 Times in 102 Posts
I almost hate to admit how screwed up I am......
When we went chasing performance in converters, I would order an exact duplicate of what was in the car and then A-B, B-A test and then compare them at a test session. If they performed exactly the same then I would send the oldest converter back to be “adjusted” If the “adjusted “ converter didn’t pick the car up then it came out and we tried something different That way you never lost what you had and that worked with Q-Jets too... No computers just 1320’ and a time slip... Marv Ripes was a way ahead of the curve when he said load up your car and come down to OCIR for a test session with 60’ clocks... He said bring work clothes and he sat at a card table with the first 60’ clocks that I had ever seen... We worked our butts off and ran 5 or 6 different converters through the race car that day and I would like to add it was a productive day
#7 | |
Liked 172 Times in 81 Posts
Hi Eric, I'm currently running Dex VI in the Pacer, have tried Dex 3 and the high viscosity Allison TES295 fluid in the past. Never saw a noticeable difference in stall speed between the 3. PM me if you like, I'll fill you in with whatever I can.
Jim Mantle V/SA 6632 Quote:
Jim Mantle U/V/SA 6632 |
