Old 07-29-2020, 11:48 AM   #1
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Recommendation for AFCO 3840f/BNC front shocks
I am looking for recommendations for the rebound and compression settings on these for my 97 S10.
60' is 1.41-1.42 and carries the front about 20' out and I still have a bounce where it slightly unloads the rear tires via driveshaft graph.
These are stock valving. Rebound is 28 from tight (~40 clicks) and compression is 8 from tight (~22 clicks).
Thank you,
Clark
Old 07-29-2020, 12:50 PM   #2
slick5861
Liked 2 Times in 2 Posts
Default Re: Recommendation for AFCO 3840f/BNC front shocks
Call Eric Folger at Afco. I have the same shocks. My car kept bouncing after a wheel stand. Revalving on his recommendation fixed everything. Very knowledgeable. Reasonable pricing on the adjustment.
slick5861 is offline   Reply With Quote
Old 07-29-2020, 04:32 PM   #3
Hacksaw
Liked 310 Times in 174 Posts
Tighten the compression, stop the bounce.
Old 07-29-2020, 04:41 PM   #4
cad
cad's Avatar
Here is a video for reference:
https://drive.google.com/file/d/1wav...ew?usp=sharing
Old 07-29-2020, 06:26 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,925 Times in 579 Posts
Originally Posted by cad View Post
Watched your video. It’s not the front. The truck spun the tires before the fronts touched. Work on getting the truck to hook and stay hooked. Check your back shocks. Do they have enough extension. I would loosen the front shocks on extension and tighten them on compression. Remove any travel limiters if you have any. What kind of tire and how much air pressure?
Mike Pearson 2485 SS
Old 08-06-2020, 10:47 AM   #6
cad
cad's Avatar
Hi Mike,
The driveshaft graph does show a little hump at about .5. The rear shocks are custom valved by Envy Suspension. They have 5.5" travel and set with 2 inches showing. I tightened up the compression on the front to Zero this past weekend....happened to pit next to Gary Stinnett at our bracket race last weekend, and he said the truck just looked stiff. In addition, we just moved the instant center to 46" out, 7.5" up and bottom bar down 1.9 degrees, and will TNT this weekend. Tires are MT 3074S with 9.5 psi and about 40 runs on them now. Gary said he thinks the tire is bouncing up and maybe even go up to 10.5 psi.
Thanks,
Clark
Old 07-29-2020, 06:52 PM   #7
Irace007
Liked 17 Times in 12 Posts
Thank you,
Clark
You could try Fast Shocks Randy & Mike Mann s
Marty Hanft
Irace007 is offline   Reply With Quote
