Old 07-11-2020, 04:37 PM   #1
rod
Liked 20 Times in 15 Posts
Default 56 Chevy rear axle?
any one have experience in putting MoPar side /axle gears in a Chevy [56-64] Dana posi. they were the same posi units, just different parts inside.
I have a line on those parts. just want to be sure they will really interchange before I move forward.
thanks
Rod in AZ
rod is offline   Reply With Quote
Old 07-12-2020, 01:40 AM   #2
dondon
Liked 10 Times in 5 Posts
Default Re: 56 Chevy rear axle?
I heard it was a common practice years ago so they could run 30 splice mopar axles. I know that chevy posi clutches are different than mopars in that one plate (chev) is about .020 or so thicker than the mopar, and the case halfs will not seat against the other. mopar clutches will work on a chev. I did put a set of chev spiders in a mopar.
dondon is offline   Reply With Quote
Old 07-13-2020, 08:05 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Yes. There was an article in either Car Craft or SS & DI in 1967 that detailed the necessary mods. There were specific MoPar axles that could be modified to fit. Today you could buy axles easily. There was a shim kit you could buy from Chevrolet parts that was used to adjust the clutch pack thickness. I did this in the summer of 1968 to a '57 Chevrolet.
Old 07-13-2020, 08:38 AM   #4
Alan Nyhus
Liked 800 Times in 237 Posts
If you're going to use a posi setup, I'd call Tom's Differentials and talk with them.
I remember that some of the differentials has 8 plates and some had 10. The spider gears were also a weak spot but I believe Tom's makes replacement high strength spider gears. They've been doing these '55-'64 style drop outs for a long time...many of the 409 guys use their stuff. Might be worth the call if you're committed to using a posi. -Al
https://tomsdifferentials.com/toma.html
"That'll never work....."
Old 07-13-2020, 12:17 PM   #5
Dwight Southerland
X2!
Old 07-13-2020, 01:43 PM   #6
Jeff Stout
Liked 708 Times in 285 Posts
My first car was a 55 Chevy in 1976. 327 4speed. I broke so many spider gears. As soon as the car wheel hopped bam. If I had only knew at the age of 16 this trick.
