Old 07-03-2020, 10:38 AM   #1
rbunton
Default 2-step controller mounting
I'm adding a 2-step to my stocker. The rule book says the controller can't be located within driver's reach, but I've seen other stockers with controller mounted on dash in front of driver. And I see no reason why it shouldn't be within the reach of the driver. Any insights?
rbunton is offline   Reply With Quote
Old 07-03-2020, 01:52 PM   #2
MR DERBY CITY
Liked 8,217 Times in 1,537 Posts
Default Re: 2-step controller mounting
With all due respect, THE RULE BOOK SAYS.......this is black and white..it’s not a grey area. I am sure this rule is NOT enforced in ALL divisions but......
Old 07-03-2020, 02:33 PM   #3
Hacksaw
Liked 314 Times in 177 Posts
You don't want the controller box anywhere with in reach anyway. Adjust it and live with your decision, stops second guessing and screwing up the run.
Old 07-03-2020, 06:49 PM   #4
rbunton
Thanks for the knowledge and advice. It will be mounted out of reach.
Old 07-03-2020, 10:12 PM   #5
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Mine is mounted on an aluminum platform in the passenger footwell along with the start/retard and ignition boxes...if I question my launch rpm decision, I just stare at it and mutter.
Dave Turner
SS/GT #1153
Old 07-04-2020, 11:21 AM   #6
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
Initially, I had mine mounted in the glovebox. It was not only out of reach, but also out of sight.
I now use a Grid and it has the 2-step function built in and they are adjustable only with a laptop.
I have also found out that the car launches better when NOT launching off the 2-step. It was a bit of a learning curve at first, as I had always used a 2-step but I got the hang of it quickly.
Thomas
NHRA 1959 E/SA
Cdncarnut is offline   Reply With Quote
