Old 04-08-2020, 10:45 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Fast xfi rpm issue
Fast xfi, analog 7al2, fast dual sync dist. My autometer tach is roughly 500rpm less than what fast data shows. Fast at idle shows 1100 while tach is around 600. Is this normal or if not, what is the fix. I honestly thought I had a low reading tach before I put on efi, just now I have another reference that should be super accurate since its dual sync
jamie2370 is offline   Reply With Quote
Old 04-09-2020, 08:26 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Fast xfi rpm issue
Sounds more like an Autometer issue.
Ed Wright 4156 SS/JA
Old 04-09-2020, 08:34 AM   #3
jamie2370
I agree, I think I will try another tach to see. Like I said, when it was a carb combo I really thought it was off then but I had nothing to compare it to
Old 04-09-2020, 09:25 AM   #4
GUMP
Liked 2,323 Times in 546 Posts
Where are you picking up the tach signal?
Old 04-09-2020, 09:57 AM   #5
jamie2370
at the 7al2 box, tach terminal
Old 04-09-2020, 10:34 AM   #6
GUMP
Is there an unused tach wire on the FAST harness? If there is, it would be worth trying before changing the tachometer.
Old 04-09-2020, 10:36 AM   #7
Signman
Liked 269 Times in 99 Posts
Have you tried the tack output in the XFI harness if I recall is the white points wire
Old 04-10-2020, 12:12 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
My last stocker, a number of years ago had an Autometer tach that was off by 500 at higher rpm and about 200-300 at lower rpm...
That was not the first Autometer tach I've had that was off but was the most inaccurate
I used an MSD ignition tester to fire the ignition and it reads rpm right on the tester. It can be used to test many items rpm related including a tach.....
Rich Biebel
S/C 1479
Stock 147R
Old 04-12-2020, 05:27 PM   #9
Ed Wright
Ed Wright's Avatar
Had an Autometer tach in my car for a while. Was wrong, just removed it. No tach now.
