Liked 227 Times in 74 Posts
Im bored your bored everybodys bored soo lets discuss fuel.....What fuel do you prefer and why? Sunoco 110, Sunoco 260 GTX,VP C11, Rocket? Has anybody tried Sunoco Surge? Better product,more consistency or easier getting you through fuel check or just faster? Lets hear it!!! Also second question what product do you recommend using to clean out your stock fuel tank getting ready for Stocker use? Thanks
Liked 237 Times in 126 Posts
Depends on compression ratio. There are two. Static, which is just the volume of the cylinder and chamber and dynamic, which takes into consideration the valve events while the motor is running. Static never changes and dynamic runs all over the place with different cams based on when the intake valve closes. Pump gas has a lot of junk in it, especially ethanol. You'd probably be burning cash above Sonoco Standard 110 leaded.
Edit: I have two home tracks. Pacific Raceways has Sonoco on pump. Bremerton will be selling Renegade 110 and 112 by the barrel this year. It's located at a municipal airport and some guys hit up on AVgas. Not recommended...
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 03-26-2020 at 01:36 AM. Reason: more stuff |
Liked 800 Times in 237 Posts
How did you determine this? -Al
"That'll never work....." |
Honestly just my opinion. He is running either a 302 or 351C in a heavy stocker. Race gas is expensive.
How does that matter?! If you want to play this game it's kinda/sorta a necessity, isn't it?
#6 | |
Liked 184 Times in 113 Posts
Used pump Sonoco high test, VP and Sonoco blends. Mostly Sunoco because that was what was most available. Lots of documenting. My engine is an LT1 iron head. I have O2 sensors and tune with factory pcm.. The best difference was 3 hundredths of a second. That was a oxygen rich day using Sunoco 110 All were same on muggy hot days. Prefer the Unleaded Sunoco 260 GTX. Seemed to do a little better than pump Sunoco. Since it was 100% gasoline. Then again minimal. This year will stick with the pump Sunoco. |
#7 | |
[QUOTE=Rose Racing;610797] What fuel do you prefer and why? Sunoco 110, Sunoco 260 GTX,VP C11, Rocket? Has anybody tried Sunoco Surge?[QUOTE]
I just use Blue Sunoco in everything. It's readily available, it (almost) always checks and it's (somewhat) reasonably priced. I would love to use Sunoco Surge as I have heard good things about it from some buds who have used it but I don't think it's on the approved list.
#9 | |
[QUOTE=Billy Nees;610827][QUOTE=Rose Racing;610797] What fuel do you prefer and why? Sunoco 110, Sunoco 260 GTX,VP C11, Rocket? Has anybody tried Sunoco Surge?
Sunoco 260 GTX Green 1.47 Maximal Light Red -0.85 MaxNOS Yellow 0.08 SR18 Yellow -1.10 Standard Light Purple -0.20 Supreme Light Blue -0.70 Surge Light Yellow -0.45 |
I'll take the second part..
Throw the stock tank away and get a fuel cell, even if you have to buy a used one on Ebay..Much easier to keep clean and to change fuels.
