Old 03-09-2020, 06:58 PM   #1
Kenney Kelley
Liked 72 Times in 36 Posts
Default Transmission Solenoids
How does one check solenoids if they don't have a factory computer? Someone told me that's how you check them. Or do you just buy new ones Thank You Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 03-10-2020, 12:50 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Transmission Solenoids
You mean the transbrake one? Internal or external? A transbrake solinoid is basically an electromagnetic switch. Give it power and ground. If it clicks it's OK. If not Not.
Dale Shearon
68 Mustang 6394
Old 03-10-2020, 01:54 PM   #3
Eman
Liked 133 Times in 76 Posts
You can use a wiring diagram and go to the connector at the trans or you can pull the pan to access them. Then you can use an ohm meter and or run jumpers to see if they activate, you can hear them click. Now that will check the solenoid but you won't know if there is a problem in controls or wiring.
Old 03-10-2020, 04:05 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
It depends what type of solenoid you have , Some solenoids are on/off valves , some regulate a pressure , and most external trans brake solenoids provide a force on a valve . The on/off and trans brake solenoids can usually be checked by just energizing them with 12 volts. The solenoids that regulate a pressure need a voltage source that cycles on and off at a given HZ but gives you the ability to control the time its off verses the time its on . Do you know what type of solenoid you have , or what its used to control ?
ss3011 is online now   Reply With Quote
Old 03-11-2020, 12:58 PM   #5
Kenney Kelley
Its a 350 Turbo it's a Stock elim transmission so no trans brake. It didn't shift last Friday at Gainesville it didn't act right on the burnout or when it left the line. So we loaded it up and came home. I need to put it on the lift and pull the pan and go from there. I thank both of you for the Info you have provided. Thank You Kenney Kelley
Old 03-11-2020, 01:52 PM   #6
pmrphil
Liked 401 Times in 154 Posts
I thought there weren't any solenoids in a T-350? Something I am missing? I know I'm a polock, but still.
Phil Molski
PMR Performance
S/C 1623
Old 03-11-2020, 01:58 PM   #7
Kenney Kelley
I thought it was 200 but my brother said it was 350 but as soon as I get it on the lift i'll know. Thanks Kenney Kelley
Old 03-11-2020, 08:11 PM   #8
ss3011
ss3011's Avatar
Sounds like your trans has a aftermarket "E" valve body . The type of solenoids used in this type of racing vb are the on/off type .
Did it shift at all or just stay in one gear ? Does the car have an e shift controller like the one Turbo Action sells ?
Old 09-09-2020, 10:04 PM   #9
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
I think the car has to be 1988 and up.Must have electronic fuel injection or a super stock car
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 09-09-2020, 10:29 PM   #10
Kenney Kelley
It's a 95 Camaro with a T-350 Pro Trans Transmission
Kenney Kelley
