Liked 8 Times in 3 Posts
Got a 69 camaro 255/350
I’d like to reduce the amount of camber that happens when fronts are off the ground , most stockers I see do not have excessive negative camber during a wheel stand I’ve thought of trying tall upper ball joints but not 100% sure that’s all that needs to be done. |
Liked 551 Times in 215 Posts
Jack Arnew from the Baltimore area is/was the man when it comes to fixing that problem. Upper A-frame mods along with other changes was what most people did.
The last 1-2 inches of up travel is when the camber goes extremely negative. If you limit front end up travel, you get rid of a lot of that camber change....
