Liked 75 Times in 28 Posts
Putting together a stocker bottom end and I have 3 blocks to choose from.
The best block checks out with a minimum of .171 cylinder wall thickness. Before machine work is done. My pistons are .060 over. The question I have is, would you fill the block or sleeve all eight cylinders? I've had someone tell me do not fill the blocks you will lose ring seal. Last edited by littlemanjoe; 09-14-2019 at 08:13 AM. |
Liked 54 Times in 33 Posts
The reason to fill blocks is to preserve ring seal. Increases rigidity. Fill as high as possible leaving 1-1/2" at the top.
Liked 450 Times in 133 Posts
We always ran filled blocks never had any problems with ring seal but i never had a mopar if that makes any difference.
Jerry Retired 3490 3492 STK SS SST |
Liked 2,477 Times in 697 Posts
Is .171 on thrust side of cylinder.
That is the most significant spot.
Yes on the thrust side towards the bottom.
I would rather see it on the bottom than the top
for the thinner side. My big blocks are thicker than that by .030/.040. I think you would be fine with a filled block at that dimension. Sometimes my filled blocks leaked better after they had been reringed once....But they were still decent the first time.
