Old 08-13-2019, 10:58 PM   #1
MR DERBY CITY
Liked 7,936 Times in 1,518 Posts
Default Stocker brake fluid recommendations....
Just curious , anyone run synthetic brake fluid in their Stockers ? Thanks in advance for any reply’s....
Old 08-14-2019, 01:18 AM   #2
tomcraig
Default Re: Stocker brake fluid recommendations....
Been running DOT5 in my car for about 10yrs.
tomcraig is offline   Reply With Quote
Old 08-14-2019, 06:31 AM   #3
Liked 10,695 Times in 2,227 Posts
Why would you change from DOT 3 to DOT 5. I would like to know. Thanks
Old 08-14-2019, 07:00 AM   #4
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
Since DOT 5 is not recommended for ABS brakes and I frequently tap into my "race" fluids for the street cars/trucks I do not keep in around. Use DOT 4 but not for the higher boiling point but because you can get it in colors so that you can readily tell when you've flushed out the old and replaced it with new. Any way it goes you need one of these:
https://www.turnermotorsport.com/p-3...-fluid-tester/
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-14-2019, 09:31 AM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 866 Times in 235 Posts
I use Wilwood Super 570 fluid in my SG car stopping at nearly 170 and all the S/SS cars I work on .
Its boiling point of 570 degrees is the highest of any DOT 3-4 type fluid.
This means it can absorb more moisture from the atmosphere as all glycol based fluids do without boiling at low temperatures.
Silicone DOT 5 fluids are not hygroscopic ,so they do not absorb the moisture that enters the system ,meaning that the water absorbed will stay separated, and boil at 212 degrees, causing a softer pedal.
Dot 5 should never be used for racing.
One thing that most Drag racers do not do regularly is flush out and change the brake fluid.
When you see cloudiness or dark discoloration of the fluid, thats a warning sign of contamination and overheating . ....This is what leads to most brake master cylinder and caliper failures . the seals themselves dont actually fail , its the corrosion of the bores caused by the contaminants in the fluid.
The fluid should ALWAYS be clean and clear as it came from the container. ....You can get a battery operated test pen for about $25 ,quick easy way to check the fluid condition.
I service some amateur road race Corvettes . ...The sanctioning body REQUIRES the brake fluid be changed before each event and certified ,along with other components by a certified inspector.
Tom Goldman is online now   Reply With Quote
Old 08-14-2019, 10:52 AM   #6
fordteacherguy
Liked 160 Times in 51 Posts
Brake fluid has changed over the years...modern HP vehicles use synthetic brake fluid.
Dot 5.1 is glycol based synthetic brake fluid with 500 degree boiling boiling point and "normal" brake fluid viscosity. Available anywhere...........absorbs moisture as well...and still need to be changed but good stuff.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
