Old 08-02-2019, 10:19 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Spare tire
Switched over from factory fuel tank to trunk mounted cell. No way can I get a 13,14 or 15" tire/wheel back in the trunk. Can I just mount a rim in the factory spare tire location?
House of Darts is offline   Reply With Quote
Old 08-02-2019, 11:45 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: Spare tire
Is there a requirement to carry a spare tire? I've never seen anything in the rulebook, although if you're looking to add some "legal" weight to your car that may be one way. I've heard stories of folks who added things other than air to the spare, and tech inspectors who aggravated hernias inspecting them!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 08-03-2019, 02:45 AM   #3
GTX JOHN
Easier for us to just bolt some weight in or install a weight box.
John Irving
741 Stock
741 Super Stock
Old 08-06-2019, 12:11 PM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I used to use an 8.20 x 15 recapped 8 ply snow tire (sometimes full of water)...
Back in the day there was no such thing as ballast.
Either bolt the weight in, in the location that you want or use a weight box.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 08-08-2019, 08:59 PM   #5
Dave Gantz
Liked 251 Times in 125 Posts
Let's go back to this. Is it a requirement to have a spare? Or has it been a way to add weight in the past that's not needed now?
Old 08-08-2019, 10:42 PM   #6
james schaechter
Liked 1,443 Times in 302 Posts
In stock it is not required, but can be used as additional weight beyond the weight box. One thing Travis used to look at was that it was at least something that you could bolt in the car. Correct bolt circle etc. we use a bumper jack and the original hold down on our 66 Nova sometimes when we run a heavier class.
James Schaechter 3163 STK
Old 08-06-2019, 04:22 PM   #7
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
I would think that you could run the wheel. I use to run some heavy mufflers hanging under car. They were not hooked up but needed the weight.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 08-06-2019, 07:54 PM   #8
R. Thorne
Liked 107 Times in 35 Posts
Have you tried one of the “space saver” oem type spare tire/wheel combinations?
R. Thorne is offline   Reply With Quote
Old 08-07-2019, 06:12 PM   #9
House of Darts
I thought about that but am not sure if its legal considering its not available for the combo. Pulled a 13" rim w/o a tire and it cleared. Have the battery and fuel relay mounted where the the weight box would go.
Old 08-07-2019, 09:01 PM   #10
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
I would think it would be considered removeable ballast and be legal in that respect. No different than a barbell weight.
Mike Moller
NHRA 203 Q-R-T/SA
