Liked 272 Times in 108 Posts
C.E., 50-50,s? Single adj? Need bank loan for double adjustable
Liked 299 Times in 48 Posts
Depends what you have for power, trans and what your goals are with the car. Every shock and brand has it's place and cars that they will work well with. As you want to go faster to 60' or want to improve consistency overall - that's when higher quality/tolerance shocks with more adjustments will help.
What are you working with and what are you trying to achieve with this car? Mike |
96 Camaro LT1 metric 200 9"X30" Radial B/SA C/SA SS/JA
For some reason the car is blowing the tires off not at the initial hit...but 2-3 feet out with the front wheels still up. After looking everything over pretty good, the only suspect we found was a very old pair of shocks.the compression adjustment is working fine, but they're really soft on the extension. |
I went with Strange single adjustable
We'll see how it does |
Sounds to me like compression may be too soft, allowing the tires to unload. Before I had Dewayne Custer work his magic, I had Stock rear suspension & 9" tires. Had to go to very firm compression rear shocks to cure that. Soft extension, firm compression. Much like those old "90-10" front shocks we used to use.
Ed Wright 4156 SS/JA |
Liked 431 Times in 224 Posts
My initial thought is that maybe the shocks were too soft, and the car was unloading when the shocks topped out at full extension.
On a good track I always run my single-adjustables at full stiff with leaf springs and Cal-Tracs. Not sure if the stiff extension or compression is providing the most benefit.
S/ST 51 S/C 53 |
