Liked 150 Times in 41 Posts
I have a original Fast system with external Fast ecu data logger, i am trying to hook up the data logger. I know the arming wire and trigger wire need to be grounded to work. My question is can the trigger wire be hooked up to a momentary switch to ground, or does it need to stay grounded for the entire run for it to log. I called Fast and they could not answer my question, I was told they do not remember on the old system. Thanks in advance Jim.
#2 | |
Ed Wright 4156 SS/JA |
Liked 28 Times in 15 Posts
Jim they bought the data logger -didn't even make it! Both units obsolete - and no one there can help. I don't have the book available but I never had a momentary switch so a constant ground works. I turned it on at staging and off after finish line. Believe it runs for a 60 second time -
#4 | |
Thanks for the replies guys. I talked to Matt Maxwell at Fast he sent me instructions. I know i can just put it on a toggle to ground but wanted to arm it with one switch and then trigger with another when ready to log. Just thinking i do not need to see all the staging data, or waiting on someone else to stage. Thanks again
#6 | |
Liked 502 Times in 130 Posts
Eric
Eric Merryfield 1883 STK |
#7 | |
Liked 66 Times in 31 Posts
I have the classic FAST and I called them today and they couldn't tell me how to wire the data logger. They did tell me that the diagram for it is in the software in the ecu. I was told to hook up my laptop and there would be a dropdown for wiring schematics.
