Liked 32 Times in 28 Posts
Looking for input on the Renegade RM K-16 Drag Elite specifically. I have been running the VP Q-16 for the past 4/years but I am thinking about switching to the Renegade.
I know both are "oxygenated" fuels., both need plenty of volume and both are good with higher compression naturally aspirated engines. Is there a front runner out of the two or not? Just curious, Thanks. |
Liked 8 Times in 6 Posts
Try X16 car stayed a bit more consistent then Q.
Class Racer Magazine Writer Super Comp A197 |
So this X16 is VP? The problem I was having with the VP Q16 was I just could not get enough fuel too a couple of the cylinders. Even with the biggest jet I could find.
Liked 241 Times in 126 Posts
What are you using for a carburetor?
I would be looking at decreasing the high speed air bleed size if you have increased to the "largest available" jet and saw no improvement. You don't have a fuel issue, you have a carburetor issue. |
Steve,
I run two 3/circuit 1150 Quick Fuel carburetor's. The air bleeds that I'm currently running are as follows: Idle-47 Inter-85 High-28 |
Did you lose any mph when you jetted up?
Based on the numbers you posted, your intermediate circuit may be too large creating the lean condition at WOT, as the intermediate is still in operation in conjunction with the high speed circuit at WOT. |
