Old 10-31-2018, 11:22 AM   #1
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
Default Trying Merge Collectors
Is there a formula when going from conventional collector's to a merge in reference to shortening the primary tube by how much to start on a 1 5/8" x 33" on a 4-1 header low HP Low RPM V8 - Thank's in advance any input is appreciated
BA1927 is offline   Reply With Quote
Old 10-31-2018, 12:23 PM   #2
GTX JOHN
Default Re: Trying Merge Collectors
We do not change primary length.
John Irving
741 Stock
741 Super Stock
Old 10-31-2018, 01:34 PM   #3
BA1927
BA1927's Avatar
Ok I have been told bye a reputable Header Mfg that they should be shortened to take full advantage of the collector and I just didn't know how much but thank you for the response - John DID YOU find an improvement and if so immediately or did you make other changes as well - Thanks Bob
Old 10-31-2018, 01:43 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
I’d recommend calling Mark Lelchook of Performance Welding. Based on your combination and current header he can get you pretty close. Highly recommend buying the collectors from him, they are a pure work of art.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-31-2018, 02:27 PM   #5
BA1927
BA1927's Avatar
TY - I look him up
Old 11-01-2018, 12:53 AM   #6
GTX JOHN
I found 3 to 4 hundreds without any other changes
John Irving
741 Stock
741 Super Stock
Old 11-01-2018, 01:25 PM   #7
340Cuda
Liked 805 Times in 341 Posts
I wanted to put mine on the a coffee table rather than the race car. Great work!
Old 11-02-2018, 11:46 AM   #8
rod butcher
Liked 132 Times in 27 Posts
Just look @ Indy's qualifying sheet the past few years. Performance Welding gets it done.
Nuff said.
Rod
rod butcher is offline   Reply With Quote
