Liked 53 Times in 38 Posts
Is an Accusump legal in Stock? I think it would really help my 340 live but I definitely don't want to go to the trouble then get bumped.
Thanks, Mike |
Yes
AND Good idea
Liked 346 Times in 126 Posts
what size were you going to use?
I think I have the 2 quart Morroso (no decal) electric shut off but I'll do a manual valve instead. More changes to the oil pump-passages also.
Liked 920 Times in 259 Posts
I ran a 3qt. unit and used an electric valve with a separate switch for it. This allowed us to prime the engine on a cold start. Shutting it off after starting the engine allowed it to charge back up. Turned the valve on going into the water, so it was active for the entire run, and then shut the valve off after making the turn off so the can could be recharged coming back the return road and/or back to the lanes. Worked great for me. I would want one on anything with a wet sump system.
#7 | |
Liked 70 Times in 31 Posts
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
