Old 10-04-2018, 08:55 PM   #1
gnicholson
Liked 4 Times in 3 Posts
Default new super street engine
Seeing how there isn't a lot of traffic on this site in this category anymore I figured I would ask a question get some opinions. I'm thinking about building a new engine for my 70 Chevelle super street car. Right now it has a 505 inch stock block big block Chevy that made about 860 horsepower on the dyno. So it's middle-of-the-pack horsepower wise. On a decent day it'll run 138 miles an hour or so on the stop. Because I would rather not fabricate new headers and change the combination a bunch by adding a ton of horsepower I was thinking a better option might be to build a 4.625 by 4 inch 532. It would have a little better piston speed than a 4 250 Stroke motor plus it would work with my 2.125 headers. I'm thinking maybe 50 or 75 more horsepower. Enough to give me a little more top speed without having to completely redo the combination as everything works pretty well right now. What do you guys think? Would you go something like this or just go ahead and build a 1200 horse 583 or something and start over basically?
gnicholson is offline   Reply With Quote
Old 10-05-2018, 09:08 AM   #2
Keith 944
Keith 944's Avatar
Default Re: new super street engine
Personally I like the idea of keeping a small bore big stroke, if anything happened you still have room to bore.
middle of the pack is not a bad place to be. if you get going too fast it becomes hard to judge the very slow.
one other issue with going big inch is everything else in your driveline has to be bulletproof
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-05-2018, 09:37 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,231 Times in 982 Posts
Assume you’ve got a fairly heavy car (my Super Street Avenger was right at minimum and only had 600 and could run 137); lightening the car yields the same results and helps with reliability and can possibly make it react faster, depending on your setup of course.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-05-2018, 10:48 AM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I wouldn't let the headers dictate your plans. I'm a big fan of small headers; they won't blow up the dyno sheet but always seem to ET well relative to the measured power.
The 632 in my dragster only has 2.25" headers and is an underachiever at 1020 HP, but all the other guys going 8.90 at 180+ seem to need 1200+ HP to do it and I'm in that club.
I'd probably go with the longer stroke; more torque to get that car moving off the stop. And the smallish headers will help with velocity at lower RPM. Same with a smallish carb.
S/ST 51
S/C 53
Old 10-05-2018, 02:46 PM   #5
gnicholson
the car is 3150 with me. it also sets a bit high and has the aerodynamics of a similar sized brick. i plan on lowering the front a bit this winter. wanted to let the new springs take a set before cutting them. I thought it would be faster than it is to but I'm sure it's the car and not the engine. It has a 488 rear right now and is going through the traps at about 7400 RPM. I've tried a couple of different converters. Right now I have a very consistent car in the 60 and im extremely happy with how the car drives. i can fab another set of headers if i need to just trying to keep it simple. i definitively agree with staying on the small side with pri tubes.
i talked to you this last weekend in great bend tony. i have the dark red 70 chevelle. thats an awesome nova you have.
Old 10-05-2018, 03:45 PM   #6
Lenny5160
Lenny5160's Avatar
I knew you had some posts on the forum at the time we spoke! Great to actually meet you, and that Chevelle is extremely nice! I've never seen a car that said "Wagner's" on the door that wasn't mint.
S/ST 51
S/C 53
Old 10-28-2018, 10:05 PM   #7
nomad
Liked 7 Times in 4 Posts
[QUOTE=gnicholson;574346]Right now I have a very consistent car in the 60 and im extremely happy with how the car drives. i can fab another set of headers if i need to just trying to keep it simple. i definitively agree with staying on the small side with pri tubes.
[QUOTE]
If the car is very consistent why are we making changes? Is the engine worn out or do you just want to go faster?
nomad is offline   Reply With Quote
Old 11-10-2018, 11:30 AM   #8
Dewdlebug
Liked 23 Times in 15 Posts
I feel your pain Gary. However I keep reminding myself that a dial-able and consistent car will win more rounds. I sure do get tired of those cricks in my neck from looking behind me though, lol.
Let me know what you end up with. Maybe you can save me a few thousand dollars trying different stuff...
Dewdlebug is offline   Reply With Quote
