Liked 783 Times in 200 Posts
1989 Mustang LX coupe roller. (I ran it as a 92). Dark blue metallic, under carriage completely painted gray.
-10pt moly cage with thru the floor sub-frame connectors -8.8 rear with Moser 33 spline axles and aluminum spool -anti-roll bar -adjustable lowers with jacking spring perch and dbl adjustable uppers -QA1 dbl adjustable front struts with Strange dbl adjustable rear shocks -Flaming river manual rack with steering shaft -4 core radiator with electric fan -5 gallon aluminum cell with all braided lines to the front -dual XS batteries mounted in the trunk -SVE racing seats with RJS harness that is up to date -Grant steering wheel with Integrated button -VDO playback tach with Automator gauges (fuel pressure mounted on cowl) -Hole shot wheels 15X9 rears with Hoosier 30x9 Lite weight radials and 15X3 Hoosier fronts. 20 runs on everything. I ran it as Superstocker put can easily be run as stocker. Very nice car. It would need motor, trans, fuel pump and it's ready to go. Pics upon request. $10,000. 931-303-8384 Bret Velde 2003 SS/LA |
Liked 262 Times in 74 Posts
pictures?
Steve Polhill 3520 STOCK, COMP |
Sent you PM
Liked 373 Times in 131 Posts
Do you still have the car ?
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Yes Alan, I will take $8000. Really good price for a person who doesn't want to build one. Thanks
Bret Velde 2003 SS/?? |
