Old 05-06-2018, 12:36 PM   #1
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Trailer Tires OR Light Truck?
Need new tires for my 22 foot enclosed trailer, what are the differences and or benefits to using either the trailer tires or light truck tires?
225/75r15’s at 60psi is what I had been using but one bubbled the other split. About 6 years old.
Thanks
Rich
Old 05-06-2018, 01:42 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: Trsiler Tiers OR Light Truck?
I have been using and having good luck with Maxis load range E on our three axle 32 footer. But just found out yesterday that Hercules is offering a load range F very soon. The load range is carrys more air and should be a better tire for the way we use them.
Painter is offline   Reply With Quote
Old 05-07-2018, 08:50 AM   #3
Pistol Pete
Pistol Pete's Avatar
Liked 769 Times in 206 Posts
I also had the Maxis 15" tire on my trailer, load range E.
That was a very good tire.
Main thing during the season if it sits outside is to cover them & Always check your
tire pressure before going to the next race.
And Great advice by Tom Goldman with the valve stems.
"Pistol" Pete Dutko
Old 05-07-2018, 10:30 AM   #4
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
and stay away from carlisles....
Old 05-07-2018, 11:13 AM   #5
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
OK after two Blow Outs ... !
Who makes the best trailer trailers tires other than Goodyear..
Looks like they are a great tire and the most expensive.
My wagon for towing uses Nitto's as they have a load ratings 250 lbs better than any other tires.
Dan
Old 05-07-2018, 01:12 PM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 857 Times in 234 Posts
Dan
$128 a tire is hardly expensive if you factor the cost of damage from a blow out or worse if you loose control !
Old 05-07-2018, 01:38 PM   #7
Dave Casey
Liked 769 Times in 162 Posts
Dan
What was the brand and age of the 2 blowouts ?
Dave Casey 1330 STK
Old 05-06-2018, 01:47 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Trailer tires are going to fail you by the time they are 5 years old.
Switching to 16" wheels and LT tires is what many people do for better reliability.
Goodyear came out with an E rated 15" tire last year and they are called Endurance and made in the USA
I had Goodyear Marathons and they started to come apart but were probably 5 +years old.
I have never had a trailer tire that didn't dry rot crack or come apart if it was that old.
Going to 16" wheels aggravates loading a lower car or a dragster....and that's what I have....
I put a set of those Goodyear Endurance tires on last year and they are a good looking tire.....80lbs air...
I was heading home from Atco yesterday on the NJTP 70-75mph just staying with traffic.....
Rich Biebel
S/C 1479
Stock 147R
Old 05-06-2018, 02:00 PM   #9
House of Darts
Liked 20 Times in 15 Posts
Most of the 15" trailer tires are made overseas. Their ratings are very dubious. A 15" tire with a 10 ply rating is a better method of judging a tire.
House of Darts is offline   Reply With Quote
Old 05-06-2018, 03:27 PM   #10
GTX JOHN
Liked 2,425 Times in 687 Posts
My boy is one of largest Trailer Dealers in Nevada. He suggests a 16 Inch tire = if it will fit.
He sells a lot of 235/85/16 E tires and rims for retro fit (About a $160.00 deal for racers at races).
If you order a new trailer = spec it for 16 tires so they put a fender on it that has adequate clearance
(Some Manufactures use fenders with minimal clearance). The G rated tires are readily available in 16
235/85 size and that is what we run on everything...... another 20 to 25 a tire but worth it to me out here in
the Desert.
We use Race Ramps or put the Dually truck on Rhino Ramps ( Not our Bus ) if needed but the height difference
is not that much.
When you buy a trailer.......Look for Dexter Axles!
The Chinese axles are.......Cr*p!
Never run a Trailer Tire OVER 5 years or you are risking you life IMO!
We never run our personal trailers over 2 to 3 years.......Saves a lot of problems
Generally the tires are date coded....I have seen some Dealers with a 2 or even 3 years old tires on new trailers!
John Irving
741 Stock
741 Super Stock
