Liked 6 Times in 4 Posts
What do you all put in water in radiator to keep from getting rusty looking? I took motor out and apart for some head work and the water looks like it came out of a old tractor that been setting for years. Motor was only together for 9 months. It is a dart block
I use Water Wetter it seems to work pretty good.
Liked 120 Times in 53 Posts
How do you clean out a rusty cooling system like the one described above. I'm looking to clean it in the car, not tear down the engine. Thanks
Liked 346 Times in 126 Posts
I have not tried this product Thermocure made by evapo-rust but have seen it on tv looks to work excellent. Paul
Liked 1,034 Times in 368 Posts
https://www.summitracing.com/parts/jgr-50030
We used this for a while . Still have 5 or 6 bottles around here somewhere. Works well, but it foams a little in a unpressurized system ..We only used half a bottle per fill
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 02-13-2018 at 10:29 AM. |
#7 | |
Liked 920 Times in 259 Posts
I used Justice Brothers products because I sold them and they worked well. Any quality anti-rust product should prevent the coolant from turning to mud. |
Liked 706 Times in 283 Posts
Could you use CLR safely to clean? I always thought if you drain water and let metal sit exposed to air it would promote rust
Liked 20 Times in 9 Posts
You can put about a gallon of cleaning vinegar in the radiator and let it circulate for 5 or so minutes and let it sit over night and then water hose it out then fill the system with fresh water and circulate that for 5 or so minutes and dump it. It will clean out the rust and scale in the block and radiator, you just to flush it ienough to get the water back neutral.
7015 E/SA Sooner Storm |
Liked 133 Times in 76 Posts
Your results may vary, all I can tell you is what worked for me. Years of rust in the radiator with a SBC with iron heads and aluminum radiator. I tried every combo of additives and lubes from water pump lube to lucas additive and others in between and still had rust, always used distilled water. One year I actually read the directions on the bottle of Lucas coolant additive and it said do not use distilled water. Since then I use Lucas additive with gallon bottles of store bought drinking water. No more rust.
