Old 01-14-2018, 09:42 AM   #1
ghost
Liked 16 Times in 11 Posts
Default powerglide question
If you run Powerglide with pro tree brake (push button for reverse) you have 2 safety
it's safe, what the problem?
ghost is offline   Reply With Quote
Old 01-14-2018, 10:07 AM   #2
pmrphil
Liked 397 Times in 153 Posts
Default Re: powerglide question
Not quite sure what you're asking???
Phil Molski
PMR Performance
S/C 1623
Old 01-14-2018, 10:39 AM   #3
ghost
It is dangerous to push in neutral after the win light? i have pro tree brake (button must be actived for reverse)
Old 01-15-2018, 10:15 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 887 Times in 239 Posts
I've neutraled and shut off my SG Powerglide for thousands of runs with zero problems .
There is plenty of lubrication for the tailshaft ,especially since so many run the roller bearings.
Old 01-14-2018, 10:39 AM   #5
jmcarter
jmcarter's Avatar
Liked 3,236 Times in 984 Posts
Don't be frustrated ghost; being from Quebec I'm guessing French is your first language...you might try running it through one of the translator apps...and no, not a danger clicking it into neutral.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-14-2018, 11:20 AM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If its a forward pattern VB its probably safe . A reverse pattern VB that by accident goes back into 1st gear instead of going from High gear to Neutral might be a problem. That is why there are a few VB's out there , that have a clean Neutral , so you never have to shift across a lower gear to get back to Neutral .
Old 01-14-2018, 11:31 AM   #7
ghost
Merci beaucoup
Thankyou
Old 01-14-2018, 03:50 PM   #8
L79racer
L79racer's Avatar
I thought it was bad to put a glide into neutral after crossing the line as it over spins the drum and can explode?
L79racer is offline   Reply With Quote
