Will a 10.5x29.5 or 10.5x30.0 fit under stock 1992 firebird rear well, and if so what rim width and back-spacing do you recommend ? Thanks, Larry
Liked 133 Times in 76 Posts
I've got an 85 Camaro bracket car. I've done extensive modifications to fit my 29.5x10.5W MT's on 10" rims with 6.5BS. Even with 5.5 BS it takes a lot of modifying. Since mine is a bracket car the cutting pounding and grinding don't matter, but on a stocker I doubt it will fly. I actually mini tubbed the front of the inner wheelwell back when I had 29x10.5 Hoosiers and 5.5 BS. it took removing the coil springs and cutting off all of the bulge where the coils sat, i went to coilovers. The 29.5 MT slick is very big, the 29.5 PBRS have a little more room. My car has a 9" from a 71 Torino under it, the width is close to stock.
Thanks,Eman This is a bracket car also
Liked 205 Times in 93 Posts
wolfe racecraft make a nice mini tub for that car...
The problems are really at the frt. lower factory tub of the wheelwell. Hrd to fit much on a 10" wheel with the way that frt section is shaped. I used a sawzall and cut the frt. section out and made a box. Then as time progressed and i tried the 29.5x10.5W It took a lot more cutting. If I was starting over with one of these bodies I either would have back halfed the car for big tires or at the very least cut a lot more out. The factory coil spring pockets are a problem area as the bulge into the tire space. Either commit to the sawzall or stay with stocker size tires and make the suspension work. Small tires can be a liability on many tracks when bracket racing, especially if you build power or have a lot of starting line ratio.
