Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 11-29-2017, 03:40 PM   #1
theman440
theman440's Avatar
Liked 21 Times in 12 Posts
Default Cylinder wall thickness
A question for the engine builders here on CR - What would be a minimum cyl wall thickness you would want to see? The block is a factory Mopar 440 for a bracket car shootin for 700-750 hp.
Thank you
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 12-01-2017, 05:46 AM   #2
GTX JOHN
Liked 1,809 Times in 572 Posts
Default Re: Cylinder wall thickness
I would want .175 or more at finished overbore in a big block mopar or .135 in small block mopar.
John Irving
741 Stock
741 Super Stock
Old 12-01-2017, 08:16 PM   #3
theman440
theman440's Avatar
Thanks John,
Are you back in town? - you happen to have a sonic checker? call me I still need some wheels.
Jeff Dudgeon
"the Flying Brick"
Old 12-21-2017, 11:45 PM   #4
Paul Precht
Paul Precht's Avatar
Liked 224 Times in 89 Posts
The only blocks that are that are thick are the 413 industrial and motorhome, most 440s are less than .175" before boring and 700HP would be about the safe limit IMO. The aftermarket blocks are the way to go if you can get one. The 400 blocks are a bit stronger in the web area and more rigid due to the shorter cylinder length. A 400 block filled Halco machine grout and Pro-Gram Engineering main caps would be a good start.
Paul Precht is online now   Reply With Quote
Old 12-28-2017, 08:52 AM   #5
Todd Gross
Liked 56 Times in 24 Posts
There were some thick blocks in 67-69 era. Back when I was more adventurous, we took some old blocks, filled them, bored/honed to 4.560 and put a 4.625 stroke to make an alcohol 604" It required a main girdle and good caps to hold things since the cylinder walls were at .060" +/- a little.
They didn't stay round very long as one might expect. That was back around 1990 and the only aftermarket blocks were KB. Thought it was worth a try. It wasn't.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 01-01-2018, 11:35 PM   #6
GTX JOHN
We have seen thick and thin blocks......No matter what year
the 440 blocks are. Just have to check them.
John Irving
741 Stock
741 Super Stock
Old 01-08-2021, 11:42 AM   #7
Chuck Gallagher
Liked 133 Times in 28 Posts
Jeff:
Engine blocks are like home made cakes from an oven. The quality really depends on the ingredients, and the maker, and the available controls as to how well they turn out..
Two identical (brand) blocks from different foundries, both following the same prints, are not usually going to be the same. A block with a higher carbon content and precision casting core control could be more likely to hold the cylinder walls shape (round and straight) and have stronger main webs then a much thicker block that had lower carbon in the iron and poorer control of the casting cores.
High volume production blocks generally are not going to result in castings that will hold their shape at the horsepower levels (600+) racers want. This is why todays purpose designed racing blocks are, in the majority of cases, cast using compacted graphite which is more robust but also more expensive.
So before investing in machining any recycled production block, I would recommend that you test the block for hardness of the material and the amount of core shift that may be present and if a new racing equivalent is available from a reliable source.
You don't want to end up with an engine with a cracked main web or seven perfect and one bad cylinder.
Chuck Gallagher
Chuck Gallagher is offline   Reply With Quote
Old 01-08-2021, 12:34 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 510 Times in 200 Posts
What Chuck said is accurate and back in my engine shop days we hardness tested and sonic tested most Small Block Chevys and any block that was going to be potentially used for a race engine....
The Hardness test was easy using a Brinell tester and the blocks had a pretty wide spread on the numbers that you got on the test..
An ideal block was at the high end of the hardness scale and had thrust walls that would be .200" or more when finished.
You can easily see a badly core shifted block just by the cam hole and the machined surface at the face of it. The sonic test will show the cylinder walls being offset usually on a block with visible shift at the cam hole...
I was buidling a 383 for a friend and the block was so offset I could not get rods to clear one side at the bottom of the cylinders and the other side went right by......I changed what rods I was using for it just to make the fit and not grind the heck out of the block and potentially break thru to the water jacket....The crank and cam were not centered in the casting by a fair amount.....GM had some real odd ways of machining engine parts.....BB Chevy Iron heads is a good example.......Guide bores not centered with the guide OD
The Brinell numbers were from a low of around 200 to a high of around 245.....
A nice early 4 bolt 010 block with nodular caps was the best you could hope to find with good hardness and cylinder wall thickness....
Aftermarket blocks are a ton better......
Rich Biebel
S/C 1479
Old 01-26-2021, 10:43 AM   #9
Ralph A Powell
Liked 202 Times in 123 Posts
Aftermarket blocks have much better tooling ( has been used in production for years) and in most cases poured in lower volume foundries.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
