Liked 310 Times in 174 Posts
After recommendations from members on this site in the Spring, re: srw or drw trucks towing a large trailer and the safety involved, I decided to try a Dually and so far I am very happy.Towing with a 2003 Dodge Ram Dually, 2wd 5.7 Cummings diesel, goose neck trailer, total pkg weighs under 22000 lbs. Don't know gear ratio but 70 mph is 1950 rpm. Only getting 10 to 10.5 mpg. This seems low to me. Any help and where is the first place to look/change ???
Liked 275 Times in 76 Posts
Do you have a tuner or exhaust mods?
I have a 2002 Dodge 3500 dually 2wd 6 speed manual and pull a heavy 48' LQ GN. My truck has an Edge Juice with attitude tuner with 4" exhaust. The truck has 4.11 gears and at 75-78 MPH it's turning 2200. I avg 10-11 MPG and have no problem pulling hills or passing slower traffic. The tuner makes a huge difference and is like night and day on my truck. The attitude gives you the ability to see boost, EGT IAT, and the ability to switch up to 5 modes. It was well worth the money. Sean
I have a Bully Dog. Tried 3 different modes and either one seemed to effect mileage only perf. Recently fried the auto trans and since the rebuild I have not used the tuner. It's got 4" exhaust.
So is 10 mpg all I should expect? I've heard claims of 15 mpg.
I thought maybe someone else would chime in?? The best mileage I get with mine not towing is 18-21 MPG, at 75 to 82 MPH, turning 2200 to 2400 RPM. My truck only has 114,000 on it. To be quite honest with an Auto and yours being a 03 that's seems like a reasonable number. If someone is getting 15 MPH there is no way they are pulling a 22,000 lb trailer!
Liked 1,924 Times in 578 Posts
That's about what you can expect from that truck. I have had numerous diesel dually's and they all get about the same mileage. 9-10 towing a big heavy trailer. Mine weighs about 16K. you might get a bit more if you have a tail wind of tailgate a semi. My buddy has a 5.9 dodge and it gets about 10 - 11 mpg right next to me. I have had Fords and Duramax. They all get the same.
Mike Pearson 2485 SS |
Did an accurate check of fuel mileage from this past weekend. Drove some hiway at 65 mph and some back roads at 55 mph. The math says 9.7 mpg.
Liked 346 Times in 126 Posts
what do you get when not towing. I have the 99 version and get between 17 and 19mpg
Sean: The truck and trailer total weight is under 22,000 lbs. Rarely use the truck without the trailer, but if the overhead indicator is at all accurate I'm over 21 mpg.
Liked 3,178 Times in 972 Posts
Based on my experience with two 5.9 Cummins (both with manuals) 10.5 MPG seems reasonable, particularly towing 70. Have you tried towing at about 1500-1600 RPM? You're likely to get 2-3 MPG improvement and then you can do a cost analysis to see if a gear change is reasonable.
BTW your indicator is probably optimistic by at least a couple of MPG. Also, unless you plan on burning up another stock auto best leave the tuner stuff unhooked.
