Liked 4,388 Times in 504 Posts
Addicted to finding that perfect tune..I picked up a 4 channel wideband and put them in the right bank and also put a 5th sensor in that collector. The header sensors are all located 10 inches downstream. Made a run and The collector sensor reads 1 unit leaner than the header sensors. Just wondering if that's normal, is that fuel still burning on its way down the header? I wouldn't think fresh air is making its way in the collector at WOT.
Bobby, you would expect all widebands systems would report the same air/fuel ratio in the same engine, same run. Would certainly be nice. But, they do not. All we can do is find what numbers, with what we have, that makes our car fastest. Even different sensors often give a little different data, same car, same location. I buy an extra sensor for mine before it is needed.
Ed Wright 4156 SS/JA |
Liked 230 Times in 75 Posts
Hey Bobby i just use the # as reference and move your target richer or leaner and go off the time slip at what it likes. I tell people how lean i run my car and cant believe i don't have holes in the pistons. ever sensor is different.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 269 Times in 99 Posts
Bobby
Would think that either and both can be happening. If your rich fuel can be burning in the primary tube making the O2 see lean. Even at wide open throttle fresh air can get sucked in the collector. Another variable in addition to the difference in each O2 sensor you're using a 4 channel WB assume it is a stand alone device, the 5th is being monitored by a separate device WB or EFI can also add to the variable.
Liked 22 Times in 22 Posts
I agree with your theory. However lately, like the last 12 years, all 3 engines we ran locally are 3 size jets larger then when just off the dyno. Plugs look almost black, but cars are quicker. One size bigger, we slow down, one size smaller, we slow down. Looks way rich, but quicker by enough to warrant the change.
don,t have one |
Liked 113 Times in 41 Posts
To answer the OP's question, yes, that is correct. I have found that the farther away from the exhaust port the leaner the number reads. I have seen it to be somewhere between .6 to 1.0 on the AFR ratio. The 02 closer to the port is what I believe to be a more accurate number of what the engine is running, but the collector is a good number to have a reference to make sure the two banks are running fairly balanced to each other
"Closer to the port", in a primary tube you are only seeing that one cylinder. If you have not tested with 8 widebands, you might be surprised at different the others could be.
