Old 06-10-2017, 04:28 PM   #1
rod
Liked 20 Times in 15 Posts
Default MSD ?s
did MSD make a digital 6AL in Black [rather that std. Red]? do those digital boxes get hot to the touch?
any idea why the dials have no effect? the truck starts and runs. however there is no 2 stage and no over rev. ugh.
Thanks Rod in AZ
rod is offline   Reply With Quote
Old 06-10-2017, 08:04 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: MSD ?s
Model 64253 is a digital 6AL in black, Rod. You might want to re-check the wiring for the box, as the low side limiter is only active when the light-blue wire (I think) has 12 volts applied to it. The high-side should work anytime the unit has battery power and an ignition pulse. I've never had a reason to check whether or not the unit got "hot", but I'm sure it does get "warm" in operation. Do you have a temperature gun you can check it with?
Just for the record, I've been running a Digital 6AL for a while with no issues whatsoever. And other than the dial adjustment being a pain in the neck (literally!), I have no complaints at all.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-10-2017, 08:40 PM   #3
pmrphil
Liked 398 Times in 153 Posts
Default Re: MSD ?s
I had a customer with a digital 6AL that ran "hot" - you could almost burn your hand on it !! Returned it and got another, it is normal, almost no heat at all.
Phil Molski
PMR Performance
S/C 1623
