Old 03-31-2017, 03:35 PM   #1
Rod Greene
Liked 242 Times in 81 Posts
Default Holley question
Since I have never raced a car with a Holley on it or owned one, I have question.
I am working on a 440 6bbl car for the street everything I read says take idle vacuum and divide it by 2 to figure out the correct power valve. Is there any benefit running a high flow PV? How about on a race engine. I have my old stocker engine on a run stand and am playing with the 340 6pack setup just to learn a bit about it. Any suggestions?
Thanks
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 03-31-2017, 03:42 PM   #2
Liked 10,926 Times in 2,257 Posts
Default Re: Holley question
Sorry can't help, I have zero knowledge on drive ability. Only care about WOT and air-fuel.
Old 03-31-2017, 04:25 PM   #3
Rod Greene
So Larry in your race setup do you use a Power Valve? Regular or high flow?
The more I mess with the Holleys the better I like my Thermoquad.
Old 03-31-2017, 04:34 PM   #4
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Thanks
Wouldn't run a PV on a race motor, certainly not on a stick.....whats the point! Frame of reference, I ran a stock 750 holley with a 6.5PV on my stock motor lil red express ran great, we dropped a crate motor long block with a 509 cam in it, some cheap 202 heads, and that killed the low end so much it felt like it needed a 2000 rpm higher stall convertor....put a 3.5 PV in it, and instant response, and tire shredding fun.
Eric Merryfield 1883 STK
Old 03-31-2017, 05:15 PM   #5
SSDiv6
Thanks
Rod, you need to talk to Steve Wann.
He is the guy that knows the in's&out's of the 6-bbl.
Old 03-31-2017, 07:59 PM   #6
Woodfin
Liked 288 Times in 109 Posts
A reasonable suggestion is to equip them as Chrysler did originally. Also, in high-performance street trim, a 6.5 valve is common with a single carb. I estimate a 6.5 or 5.5 will be just fine.
I expect you already know, no matter what level of tune or refinement you attain, it will get "yardage" not mileage
Old 04-02-2017, 01:27 PM   #7
Rod Greene
OK I have decided I need to step out of the dark ages and get an wide band AFR gauge.
I am thinking An Innovate LM-2 Looking on their web site and e-bay there are many options, What recommendations would you guys have? I would use it on my street cars as well as the race car.
Old 04-02-2017, 03:16 PM   #8
SSDiv6
Rod,
Before you choose the Innovate LM-2, take a look at the Daytona Sensors WEGO and the NGK.
My experience is that their reading are more reliable than the Innovative and AEM.
http://www.daytona-sensors.com/wego-...---8-cyl..html
https://www.ngksparkplugs.com/produc...-ratio-monitor
Old 04-02-2017, 08:36 PM   #9
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
On paper, the LM-2 looks good. I bought one and have had problems from day 1. Tech support ranged from decent to pretty sad. If I buy another, I'd give daytona a shot.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
