Liked 327 Times in 87 Posts
Liked 285 Times in 87 Posts
You should be able to gently tap the column flange into place. It slides out, and fasten with the 5/16NF & 3/8NF hex nuts and bolts along with the reinforcement washers supplied with the rag joint when purchased. MB
Tried that with no luck. Is it possible to slide the whole column down?
I have another column floating around. I'll check if that flange will slide out. I will post everything in my build thread but it's been a challenge to get the steering situated |
Liked 335 Times in 182 Posts
Rag joint(steering coupler)-- for 67-69 manual steering is GM # 7806391 pinch bolt is 7807271---Fed 387
67-69 Camaro PS rag joint is 7806390--Fed 387
Liked 8 Times in 7 Posts
ps boxes have different size splines/shafts that manual boxes.
is that a manual Camaro box or a vega?
without losers,winning means nothing. |
