Old 01-09-2017, 06:46 PM   #1
rod
Liked 20 Times in 15 Posts
Default A/F guage & Data storage?
what is the easiest way to store date from an A/F gauge? I have an old lap top, [heavy but can be used]. can data be put into a ipad type thing? I assume that the gauge connects to a lap top [or?] via a serial terminal at the gauge. other than buying a whole A/F set up, where can I get a graph [program] for my lap top?
I am feeling like a women in a parts store in this area.
I race only at Vegas, 2200 feet, very dry, no trees and baro changes as the wind blows [which is all day long!]
need easy help please.
thanks Rod in AZ
rod is offline   Reply With Quote
Old 01-10-2017, 02:58 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: A/F guage & Data storage?
I have a data logger of sorts from Innovate Motorsports. It hooks up to their gauges and controller and stores data on an SD card like those for cameras. The card plugs into any computer that will run Windows and uses free software to view your run.
With that, it's a bit tricky to use at the races. You have to start and stop it with a little button and if you shut the car off with it running it will mess up your data, Looking at the graph takes time to get used to because you have to learn to see where your burn out and stage stop and your pass starts. It would be better if it had an inertia switch to start it on launch and stop it on braking in the traps.
Gauge, controller and data logger go around $200 and that's cheap compared to RacePak stuff.
LINK: http://www.innovatemotorsports.com/products.php
Dale Shearon
68 Mustang 6394
