Liked 53 Times in 38 Posts
My question, can we use a floating pin if the engine came with pressed pins? I'm thinking no but... I have a new set of Eagles and was hoping I could use them.
Liked 28 Times in 15 Posts
Yes you can use floating pins. Bigger question - are the rods on the approved list?
#3 | |
I purchased them with a maybe, dude said they where Eagles, h-beam, no markings that I've seen, but not used at least. The pistons I have are correct but no clip groves, are they allowed to be cut? If this gets to much I'll use the stock ly rods. I see no reason they won't last at 5500 tp 6000 rpm. |
Liked 401 Times in 154 Posts
Careful, Eagle rods are all marked. Lots of Chinese crap copies out there.
Phil Molski PMR Performance S/C 1623 |
Liked 2,518 Times in 702 Posts
We run LY rods with good bolts to 6800 regularly and have for 40 years. They are a lot better than some of the Junk out there! We do prefer Eagle and Manley stuff in higher budget builds.
Liked 503 Times in 131 Posts
John what is a LY rod? Special flavor of factory rod? Thanks Eric
Eric Merryfield 1883 STK |
