Old 07-23-2007, 03:03 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Red face Battery Question
I have two batteries in my car. After a run one is run way down and the the other one is still fully charged. Same battery run down everytime. Checked the connections on both and cleaned connecters at the cut off switch at the back of the car. Any ideas on this one. Thanks.
Ed Carpenter
66 Chevy II
SS/H
Old 07-23-2007, 04:10 PM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Battery Question
Yeah, one of them is junk.
Don't forget the ground circuits!!!!
Always replace batteries that will be paralleled for use in date matched pairs for best results.
Manufacturer date codes are "stamped" into the battery case.
The Optima Yellow top is a good choice for no charging system, or if you can fit them, use the Group 31 truck batteries, they hold up to vibration much better than a regular automotive battery, and have great reserve capacity, which is critical to operation without an alternator.
Dave Goob Cook is offline   Reply With Quote
Old 07-24-2007, 12:08 AM   #3
Jeff Lee
Jeff Lee's Avatar
Ed,
I'll sell you a pair of these (from Jegs):
YellowTop H/D Deep-Cycle Battery
Model D31A
12-13/16"Lx6-1/2"Wx9-3/8"H
59.8 lbs
900 cold cranking amps
75 amp/hour
Reserve capacity: 155minutes
Price: $255.00
I'm converting to 16v. I have maybe 8 races on these. $250 for the pair!
Jeff Lee
JeffLeeAzRealty@Qwest.net
602-418-9797
Jeff Lee 7494 D/S '70 AMX
Old 07-27-2007, 11:51 PM   #4
Chip THELEGEND Johnson
Liked 281 Times in 79 Posts
The last 3 sets of red tops I bought were junk.
I switched to megatron (which I think are made by the same company) No problems.
Chip
p.s. buy 2 batteries
Chip THELEGEND Johnson is offline   Reply With Quote
