Old 05-07-2016, 08:36 AM   #1
DBi Racing
Default Metric 200 Pump Pressure
I'm getting around 200 psi at idle in 1st, 2nd, and 3rd gear and the pressure goes up to 250 off idle. Is that too high?
I had a converter give up on me last fall and I'm trying to figure if it was too much line pressure, or the 1000+ runs that were on the converter?
Bill Lent
O/SA 3158
DBi Racing is offline   Reply With Quote
Old 05-07-2016, 10:22 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Metric 200 Pump Pressure
Converter pressure is about 1/2 of line pressure . If the converter failed because it ballooned, then usually you will see damage on the crank thrust bearing . If the converter has ballooning plates, and is furnace brazed, it should be able to handle over 150 psi @ 7000 rpm .
