Old 05-02-2016, 11:15 PM   #1
older racer
Liked 68 Times in 26 Posts
Default Msd
hi, I see how MSD wires their relay 8961 into two step and clutch switch.
how does it switch from high side to low side?? the instructions in book doesn't tell you anything . I tried calling all three numbers, and no answer. do you have to install a switch , to select high side and low side ? just curious, as going to install the relay in a clutch car. like to know before hand. thanks
older racer is offline   Reply With Quote
Old 05-02-2016, 11:36 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: Msd
https://www.msdperformance.com/produ...ols/parts/8739
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 05-02-2016, 11:49 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: Msd
The red wire from the two step, connected to and energized by the 8961 Relay controls the high/low function when used with a clutch switch.
http://www.jegs.com/InstallationInst...1/121-8961.pdf
(See Figure #6)
Hope this helps!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 05-03-2016, 07:47 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 2,024 Times in 607 Posts
Default Re: Msd
The high side on the 2 step is always active. The low side is activated when power is applied via a switch.
Mike Pearson 2485 SS
Old 05-03-2016, 12:48 PM   #5
older racer
Default Re: Msd
hi, ok, if the line lock sets the low rpm, how do you do a burnout? won't have enough rpm to spin tires, prob slip clutch? I do my burnouts on high side, then switch to low side for launch now. I want to use their relay and rewire my system.
Old 05-03-2016, 02:03 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Msd
I think that if you want to control leave, burn out and high side rpm you would need a 3 step......or a switch to turn off 12 volts to the 2 step module with the line lock energized for your burn out
If you put in a switch there will be no RPM limiter for the burn out...
Bob
PS: Remember to turn the switch back on after burn out!!!!!!!!!!!
Are you running an automatic or stick???????????????????????????//
Bob Mulry 7516 STK
A & M Motorsports
