Liked 7 Times in 6 Posts
I've read for many years that valve lash will open .004 to .006 with this combination. Will the piston to valve clearance grow too?? I'm at .044 with everything as it will be when running except the heat.
Liked 362 Times in 105 Posts
In my experience it is more like .002 to .003 on the valves.
Not sure on the piston clearance. If it is a alum rod it will be different than a steel rod. Just My 2 Cents Rick Cates |
Liked 99 Times in 60 Posts
Ron, in my experience .044 is in the danger zone and will most likely bend valves.
I am still in recovery from valve to piston clearance interference ![]()
Larry Woodfin 471W |
With mynaluminum SBC (LT1) heads, intakes are right at .005", exh more like .003", as the exhaust valve runs much hotter than the intake, making up for some of the head growth. With greater mass of a BBC head, I would think the difference would be greater.
I have run my intake valve-to-piston clearance as close as .036", using "checking" springs. Nothing touched, but no carbon formed where the valve would have touched. I normally use .040", but you had better have everything right, and stay on top of your springs. I would not try that with stud mounted rockers.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 03-20-2016 at 12:22 PM. Reason: Forgot something.... |
Liked 887 Times in 239 Posts
My 468" Mule has 074 GM/AFR heads which grow more than modern high density castings.
I get by with .040" on the intake with no kissing , but I have titanium intake valves and very high spring pressure. I've never chanced anything less than .050 on the exhaust , but they have never touched , and it runs at 8500 rpm. Also have a belt not a chain which I think helps .
Thanks for the comments. I've never been closer than .052 on the intakes and about .075 on the exhaust. I've heard the rule of running the same intake clearance as quench is always safe. Knowing the intakes are chasing the piston is a safety factor too. I stopped using checking springs a long time ago because I couldn't get them to read anywhere near the actual spring. I think it takes much less time to check with the race spring and they're more accurate. My garage isn't heated and checking things cold always concerns me when numbers are tight.
