Old 02-13-2016, 06:35 PM   #1
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Holley 1850 replacement carb
Putting together my 396/325 BBC for my 1965 Impala. I want to run the Holley carb which came on the 1965-66 396/325 (also with Quadrajet.)
Wouldn't I be able to use aoff the shelf Holley 1850 600 CFM carb? Same Throttle bore diameters and Venturi size as a original Holley.
Would I need to ask NHRA if they would add it as a replacement carb? Has anybody ever tried this?
Old 02-13-2016, 08:42 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Holley 1850 replacement carb
That's a trick question. There isn't a listed replacement on the NHRA site for that carb. The Holley part number for the one you want to use is 0-1850 and the first paragraph of the replacement carb section of the Accepted Products document reads in part "Holley dash numbers are accepted unless otherwise noted".
Talk to Quick Fuel. They have a long list of carbs that NHRA has approved as replacements and never added to their documents.
There's no listed replacement for the Holley listed on my SBF, but QF has the SSR 585 listed on their documents as an approved replacement. More cash, which I'm out of, but nice carb.
Dale
Dale Shearon
68 Mustang 6394
Old 02-14-2016, 06:57 AM   #3
danoone
danoone's Avatar
I have a 66 396 Q jet core
danoone is offline   Reply With Quote
Old 02-14-2016, 04:13 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Tried to send you a private message. Says your full. Clear it and I will send you some info. Or e-mail me...I can't get the format to post here.
Adger Smith (Former SS)
Old 02-14-2016, 05:02 PM   #5
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
I personally took and 1850 side by side with a 3140 (the #'s correct for my 66 396) to Pomona last year and Bruce B said No Problem its OK!. You can PM me for details on this app. I already have Dyno'd this carb on a 396/325 back to back with a 3140. Also talk to Scooter Vester at Quick Fuel. He has a approved carb as well.
Overkill is Under-rated
stocker396 is offline   Reply With Quote
Old 02-15-2016, 10:13 AM   #6
Jason
Liked 8 Times in 5 Posts
Since when does a center pivot dual line Holley get to replace a square bowl single line Holley? Your photo is questionable if that is the 1850 replacement.
Jason is offline   Reply With Quote
Old 02-15-2016, 08:05 AM   #7
Dave Gantz
Liked 251 Times in 125 Posts
I'm not familiar with this at all. Could you tell me; isn't the Quadrajet bigger?
Old 02-16-2016, 02:35 PM   #8
5389stk
Liked 75 Times in 7 Posts
dyno tested holley intake 6948, vs 3948 q-jet intake same 750 holley carb on both intakes . 6948 holley intake down 20 horsepower on 425 horse 454, steve
5389stk is offline   Reply With Quote
Old 02-16-2016, 03:09 PM   #9
stocker396
stocker396's Avatar
454 is a totally different animal. 396/325 is a small valve/closed chamber/ low lift cam app. Our testing proves the Holley can work. Have not done a back to back at the track yet. Its all in the combination.
