Old 02-05-2016, 02:45 PM   #1
Lyn Smith
Liked 950 Times in 189 Posts
Default General kinetics cam Id.
I have run across a Gk cam Cic 431-f for a sbc.Can someone come up with the specs for it? Thanks
Old 02-05-2016, 04:23 PM   #2
FED 387
Liked 328 Times in 176 Posts
Default Re: General kinetics cam Id.
Try nastyz28.com website he had some old GK catalogs. Fed387
Old 02-07-2016, 11:59 AM   #3
ss wannabee
Liked 7 Times in 7 Posts
Don't think you'll find it in a catalog...Believe you have a "431" Stocker cam for the
early 283-327 engines...I had a GK catalog back in the day and the Stocker grinds
weren't listed...They DID have page saying that they did make Stock "cheater" cams
and that you had to call for info...The other major companies did the same....
This is probably because there was a lot of R & D going on and many changes...
hence the "f" connotation...in your case...betcha there was a "431-plain"..then
an "A".."B"..."C"...etc...all pretty much "different"...even though ALL met "lift-duration
and overlap as per the rules at that time...
MAYBE there's some veteran enthusiasts on here that might be familiar with these
cams...NOT sure if you can tell the AGE of the cam...whether it was ground in the
pre-1972 "hey-day"...or later...for real specifics I would try to contact whomever
bought GK's data...when they eventually closed...but it might be too much trouble...
For starters...I would try to confirm the approx. .266" lobe lift it should have...oh
BTW, I think the cam had .399" lift at the valve...and 300?-degrees advertised
duration..and of course...it was hydraulic lifter as an OEM...
Think GK favored "dwell-type" lobes...I remember when Cam Dynamics came on
the scene and offered the "7000-series" Stocker cam as an alternative...
Hope this he
ss wannabee is offline   Reply With Quote
Old 02-07-2016, 04:57 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Lyn -
If it helps, I had a GK 431-D camshaft that was 248 degrees duration @ .050" for both intake and exhaust, 110 lobe separation and .265" lobe lift. It was for 57-66 SBCs with the NHRA specs of 300 degrees duration intake and exhaust, 78 degrees overlap and the .398" valve lift. It was the first "cheater" cam I ran in the 283 Chevelles.
Old 02-07-2016, 10:22 PM   #5
Lyn Smith
Thanks for the info guys.I got it from a old stock racer that ran a 283 stocker.The lobes are the "dwell type" flat top.
