I have a 67 Fairlane 2 door Post. Owned it since 86, I am looking to convert it back from a bracket car with ladder bars to a Stock Class with a 390.
My question is that I had modified the Shock towers to gain clearance when I ran a 460. You can't tell that they have been trimmed. There not butchered. But is it still against the NHRA rules to modify the chassis like that? I have a copy of the the new rules but that part is unclear. Thanks for the help. |
Liked 237 Times in 126 Posts
Interesting...
Stock reads: FENDER SPLASH PANS Mandatory. Can be trimmed to allow a maximum of 2 inches clearance around headers. Super Stock reads: FENDER SPLASH PANS Must be retained; may be trimmed to allow 2-inch clearance around headers. Alterations to shock or spring towers prohibited. See General Regulations 7:3. Both reference General 7:3 which reads: 7:3 FENDERS In Super Stock and Stock, the leading and trailing edges of fender openings may be trimmed for tire clearance, maximum 2 inches. All vehicles in all classes must have re-rolled or beaded edges on altered fenders. Flaring or spreading external fender lines prohibited, except as noted in Class Requirements. Front fenders may not be “drooped” on full-fendered car except as noted in Class Requirements. I think Stock is a word processing error and you can't trim the shock towers. Take a photo and email it to your local tech and see what they say. Dale
Liked 262 Times in 124 Posts
Jim, if the trimmed shock towers aren't allowed in stock you could replace them. When I bought my car it had had a big block in it at some time and they use a sledge hammer to make clearance. I had a guy replace the towers with some from a donor car and you can't tell it was done. Its been good for 15 year no problem with alignment or handling. Good luck Robbie
Liked 251 Times in 125 Posts
Modified shock towers could allow for an advantage in header design. Doesn't mean they ain't legal, though...
Liked 354 Times in 120 Posts
How many remember when Ford had to change the inner fender wells to get the big blocks in the mustangs? Tom
Tom Meyer 5240 SS Stock ??? |
Liked 26 Times in 13 Posts
Quote: "How many remember when Ford had to change the inner fender wells to get the big blocks in the mustangs?"
For a production, available to the public Mustang, I think the only ones that had modified shock towers were the 69 and 70 Boss 429s. KarKraft did the work as part of the conversion of the factory cars to fit the Boss motor. The 67 and later cars were designed to fit the FE engines, although anyone who has ever tried to put headers on one of those things developed a vocabulary that would make Satan wince. The '71 and later cars have a shock tower that is significantly different than the earlier cars to fit the 429, but the car is a lot bigger overall too.
Bill Harris ex 2172 STK ex 2272 S/S |
Thank you everyone for the replies and help.
Wishing you the best in 2016. |
