on a 2009 Chev truck 5.3 is it possible to use a cast iron block, what mods do I have to do . Its for my Tow vehicle .
Liked 316 Times in 107 Posts
Should be able to swap over,just have to make sure other block is same,has place for same sensors etc.,that would most likely be only thing that would be different
Mike Taylor 3601 |
Liked 112 Times in 31 Posts
Yep. Exactly what Mike said. Just make sure it's the same generation block for sensor locations.
Rick |
Liked 229 Times in 71 Posts
Displacement on demand would have to be disabled if it was an older block and it has to have the timing chain gear with provision for cam sensor on the timing cover. Also, you have to make sure you have the correct reluctor wheel on the crankshaft which is 58x not the older 24x style.
