Old 11-18-2015, 07:32 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Low power stockers-auto or stick
I see that Paul Wong has the points lead with his 273 2BBL Belvedere. There has to be some real consistency with that low power stocker and the stick. Anyone have a guess? Paul, what's scoop. Thanks
House of Darts is offline   Reply With Quote
Old 11-19-2015, 01:10 AM   #2
Liked 5,121 Times in 1,952 Posts
Default Re: Low power stockers-auto or stick
First of all, what Paul Wong won was the National Performer Award, which is the most rounds won by a Stocker or Super Stocker, stick and auto version of each, during CLASS run offs.
Class racing is run flat out to the finish line.
I don't want to sound like I'm diminishing Paul's accomplishment in any way...
However, you don't necessarily have to be consistent...just fast!
Also Paul used his 350 4 speed C10 to win some of those rounds, and maybe another vehicle or two, also.
As far as consistency, Paul and others will probably say that's quite possible with a stick car.
Better than an automatic? Let's just say there are a few stick drivers out there that I'd never bet against.
Old 11-19-2015, 01:49 PM   #3
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Where is this list? Does NHRA post this?
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 11-19-2015, 03:46 PM   #4
I had to ask too, last month
Go to NHRA Competition> Points and stats> National Performer
Old 11-19-2015, 04:56 PM   #5
Paul Wong
Liked 419 Times in 85 Posts
You have been picking around at this for years. You just need to start getting something put together. You have mentioned several viable combinations to me over the last few years.
As much as I am a fan of the "Dime Rocket" deal, a low powered V-8 stocker with a stick will only be a dime rocket if you want to make 3-5 passes before it puts parts on the ground. Stock style transmissions clutches and rear ends will show there weaknesses very quickly. 3500 plus pounds with a stick require the same parts as an A/S car if you want to have fun and have something live. The first 10 feet is just as violent.
Automatic parts can be found more readily and will be more available for a dime rocket build.
The national performer thing is neat but not simple to chase. You have to do a lot of travelling and be ready to take horsepower to win, especially in the combo classes.
Paul Wong is offline   Reply With Quote
Old 11-19-2015, 07:07 PM   #6
Jim Caughlin
Liked 805 Times in 245 Posts
Paul,
Can't agree more. My trans, clutch and drivetrain are the same parts that a V8 super stocker would have and just as likely to break, particularly leaving at 8400 rpm. Anyone that thinks that a low HP stick car can be built on a budget needs to take a reality check. Stick with an auto if money is an issue.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 11-19-2015, 07:39 PM   #7
House of Darts
I chose an F body with the 318 4BBL. Surprisingly no rust. I have the motor in and before I chose a trans and rear combo, I just wanted to do it once and devote the time to tuning and racing. Paul, your help was put to good use. Thanks
Old 11-19-2015, 08:07 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
A budget racer is a nice concept, but by the time I got around to building a car I had watched too many of them being pushed off the track with broken rear axles and trans components. I put a bunch of cash into "power train" stuff that will last.
Just my 2 bits worth.
Dale
Dale Shearon
68 Mustang 6394
Old 11-19-2015, 08:57 PM   #9
MR DERBY CITY
Liked 7,937 Times in 1,518 Posts
A wise man once said, Buy the good parts the first time ......
Old 11-19-2015, 10:17 PM   #10
George Mirza
This combo uses probably the best automatic transmission ever used in a stocker, take advantage of it.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
