I am wondering if there is a ball park reading for an EGT reading in my SBF 289, with an automatic trans. When comparing stick shift with automatic and just different engine combos there seems to be a difference in the finally reading. Thanks for your help!
Jamie |
Liked 1,908 Times in 427 Posts
No, not really. There is only a point at which the EGT is telling you that your temperatures are so high as to signal something dangerous is going on, or so low as to signal that little or no power is being produced.
One tool you can use is Larry Meaux's PipeMax software, found at maxracesoftware.com. Enter all of your information into that program, and it will provide you with a general target EGT. Those readings are general readings to compare to dyno pulls, based on Larry's decades of experience with dyno testing.
Alan Roehrich 212A G/S |
Liked 880 Times in 311 Posts
Don't ever try to "target " an EGT as being your "Best". Too many Variables to make EGT what you tune by. BTY I've seen some real cold EGT's melt pistons. Heat in the chamber, not in the ex is what happened!! I have changed the Ex lash and lost power and got higher EGT's. I've added timing and cooled EGT's and lost power...Use EGT as a reference when you tune.
Adger Smith (Former SS) |
WE no longer use EGTs for dyno testing ,We have Wideband O2s on each cylinder and read spark plugs for tuning,EGTs will show high with a over rich condition burning fuel in the exhaust port,Easy to get lost with EGT numbers.Bill C.
Liked 25 Times in 16 Posts
I think that you would look for even EGT numbers in all the cylinders, not for an absolute value. This article is pretty much on target for EGT peaking around the stoichiometric A/F ratio, and then dropping off on either side of it. The wideband O2 sensors are probably the better solution except they get fouled by leaded fuels.
http://www.sdsefi.com/techegt.htm
Mopar 2 Ya! |
Liked 20 Times in 9 Posts
Just a curious question I thought having EGT on the exhaust was to follow which way the air fuel mixtures were going like if you had a 2 or 3 cylinder that are high on one side of the engine and lower on the other side you could try to redirect some of the mixture to balance out the cylinders.
7015 E/SA Sooner Storm |
