Old 07-29-2015, 03:18 PM   #1
njk53
Default Valve Cover Breathers
I have a theoretical case scenario I was wondering if I can get some comment on by the engine experts. If you have no valve cover breathers on either valve cover (V8 Engine of course), and are using just a PCV valve, can the crankcase pressure build high enough to cause the rear main seal to fail?
Nelson Kowal
Stock 345
Old 07-31-2015, 09:25 AM   #2
Eman
Liked 133 Times in 76 Posts
Default Re: Valve Cover Breathers
YES! A PCV system requires a breather to be a ventilation system. little or no vacum under full throttle which is when the engine is making the high amount of back pressure.
Old 07-31-2015, 11:53 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I found out by accident that you need a breather installed if you use a PCV valve system. I didn't lose a rear-main seal but I sucked a valve-cover gasket up pretty good!
Lew Silverman #2070
"The Wagon Master" N/SA
