Old 07-27-2015, 07:52 PM   #1
Woodfin
Liked 276 Times in 106 Posts
Default continous duty solenoid as master switch
Racers,
I am considering a high amp rated continuous duty solenoid as my master switch. Anyone have experience with doing this?
In my situation it will be for weight saving reasons. I have the Super 10 on a weight reduction plan and removing the hardware that allows me to operate the cutoff switch while seated and from the rear will remove about 7 pounds.
Woodfin is online now   Reply With Quote
Old 07-27-2015, 08:00 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,925 Times in 579 Posts
Default Re: continous duty solenoid as master switch
Originally Posted by Woodfin View Post
Racers,
I would just remove the system to operate from the drivers seat. It's a nice option but I have been racing for many decades and have never had a reason to use such a device. I would stay away from a solenoid as it uses power to hold in the connected position. You could look into a mechanically held contactor. They are more like a relay on steroids.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 07-27-2015, 08:26 PM   #3
bigfoot584
bigfoot584 is offline   Reply With Quote
Old 07-27-2015, 09:29 PM   #4
Ed Wright
Ed Wright's Avatar
I fully agree. KISS
Ed Wright 4156 SS/JA
Old 07-27-2015, 09:46 PM   #5
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I'm guessing you have a battery(s) mounted in the bed on the S-10? Using a continuous-duty solenoid to replace a Cole-Hersey style master cut-off switch would require you to run power to a toggle-switch of some kind inside the cab of the truck, somewhat defeating the purpose of the master-switch disconnecting all power at the battery. Better to have one mechanical disconnect at the rear for safety's sake.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-27-2015, 09:58 PM   #6
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
I could see it working with this type of rear starter solonoid system.
Might take a little more creative wiring than what is in the pic to work as "all kill" switch tho.
Old 07-27-2015, 10:36 PM   #7
Woodfin
Almack, I do not run an alternator.
