Old 06-07-2015, 09:09 PM   #1
J.R. Haddad
Liked 1,464 Times in 307 Posts
Default Accel/dfi/thuster help!!
Every time I go to hook up the Thruster Software to my Laptop I get a
message that says Couldn't open a com port on your computer. I have
downloaded drivers, entered the number of the port, re-downloaded the
software, all to no avail. Threw the laptop out the front window, no
change. Threw myself out the front window, still nothing. HELP!!
J.R. Haddad.
J.R. Haddad is offline   Reply With Quote
Old 06-07-2015, 09:44 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Accel/dfi/thuster help!!
Go to device manager with serial adapter hooked to laptop and see if it is working and the comm port number assigned to it. You can go into advanced settings and change the port number to meet your needs. Also if you,re using a serial to usb adapter make sure your laptop has the required software for it. Good luck joe
Joe Buchanan SS/BX 3117
Old 06-08-2015, 06:02 PM   #3
Bobby Fazio
Bobby Fazio's Avatar
I get that message when I forget to turn the ignition on and power up the box. But make sure the device manager settings are ok. If you are running multiple devices off the same port it can act weird. Make sure all other ports are unplugged and programs are shut down.
'65 Mustang SS/L & L/SA
