Old 04-29-2015, 08:03 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 1987 Thunderbird
anyone racing the 9th gen T-Bird package?
Not so much the engine package but what are the suspension options?
What are the interchangeable parts with other Ford products?
Larry Woodfin 471W
Old 04-29-2015, 08:17 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: 1987 Thunderbird
Larry,
Stock suspension is all interchangeable with foxbody Mustang, other than the rearend width is wider on T-bird.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 04-30-2015, 09:03 AM   #3
Tony Corley
Liked 61 Times in 25 Posts
Pretty certain that all of the T-Birds with drum brakes have a 7.5 rear, which is indeed wider than a Fox. If it is a TurboCoupe with disc brakes, then it is an 8.8. If you want to use rear disc, then an 8.8 rearend out of a 94-98 Mustang is the same overall width as the TBird. This is basically the same rearend that is in a TurboCoupe, only with 5 lugs.
The housing itself is narrower (same as a Fox), but the axle length for the disc brakes makes up the difference. If you want to run aftermarket disc brakes, then you can use the 8.8 housing from a Fox or a 94-98 Mustang (they are identical), and run axles and aftermarket brakes designed for the 94-98 Mustang. Once again, correct track width.
All of the other suspension components are a direct interchange with a Fox Mustang
Tony Corley is offline   Reply With Quote
Old 04-30-2015, 10:20 AM   #4
Dragsinger
The body does have a good aero shape and research shows it to have a very low aero drag number.
It is something I have acquired and just brain storming about it's best usage.
My Super 10 super stocker will be race ready this fall and I am always looking for the next project. Gotta keep the creative juices flowing
Building it as a stocker is an option.
Larry Woodfin 471W
Old 04-30-2015, 10:29 AM   #5
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
The rear upper and lower control arms on all 83-88 T-Birds and Cougars are different than Fox Mustangs. ( i.e. longer)
79-98 Mustang control arms will bolt on, but will not fit properly.
The 83-88 T-Bird shocks are also longer than a 79-93 Mustang, but the SN95 (94-98) Mustang shocks are the same correct length to use on the T-Bird.
This is what Mustang control arms on a T-Bird does...
moves the rear forward about 1 inch.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 04-30-2015, 11:23 AM   #6
Tony Corley
Good info Alan. I always thought the control arms were the same. I installed a set on an '86, but they were adjustable and I just adjusted them to the same length as the stock TBird lowers. obviously, not legal on a Stocker (non adjustable lowers per the rules) I also ran Fox shocks, but the car was lowered.
