Old 04-26-2015, 02:16 PM   #1
L79racer
L79racer's Avatar
Default Bad coil???
So I'm trying to figure why I lost 3 to 5 mph. Plugs are black that usually are a nice brown. carb is not dumping and my AF meter says super rich. Drop some jets no change. Could the coil not be putting out enough power. I just tested it with meter. Its a digital 6 box with a Blaster HVC ll 8253 coil. It had .07 ohms across primary terminals and .739k ohms from positive terminal to coil post.
L79racer is offline   Reply With Quote
Old 04-26-2015, 03:03 PM   #2
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Default Re: Bad coil???
Clean out your high speed air bleeds
Pedigo Perf is offline   Reply With Quote
Old 04-26-2015, 05:12 PM   #3
GTX JOHN
I have had the HVC II coils (Red and Blue) malfunction sometimes without
any warning. I would try to borrow a Blue one from someone and try it
a pass. Even when bad........They check OK at MSD trailer but MPH falls
off 5 sometimes more!
John Irving
741 Stock
741 Super Stock
Old 04-26-2015, 08:45 PM   #4
L79racer
L79racer's Avatar
Thanks guys. I'll look into the carb and I will borrow a coil from my brother and give it a try. Hopefully thats the problem. I want the mph back.
