I was wondering how much ET could be gained (or lost) in a car that DOES NOT spin, but also does not run the ET based on the horsepower made?
Traditional 4 Link Suspension Not a lot of horsepower (560HP/450TQ) (Super Stock build) Looking to make the car 60 foot much better than it does not, however, it doesn't spin as it is. Just lazy. Thanks, JP |
Liked 99 Times in 60 Posts
JP, my experience shows in order to achieve the best ET for a given power the car must really get with it off the line. Converter [or clutch] gearing, tires, suspension, shocks, engine combination, the whole package is important.
"Lazy" will not produce the desired results. Post all the specs of your combo, you may receive some suggestions.
Larry Woodfin 471W |
#3 | |
Here it is off the top of my head! 2002 Camaro 3310 lb with driver (GTFA) 327/275(299 adjusted) (Heads up heads/intake/Boburka q-jet) 1.98 PG 5900 Stall 8in Converter 6.00 Rear gear 3073R 31.25/12.2R15W Mickey Thompson Radials (100 inch circumference) 4 Link rear suspension QA1 Single adjustable front shocks It has went 10.68 at 125.71 only 60 footing 1.46-1.47 not spinning a lick. The front end is as loose as it goes and it probably lifts the wheels 6-10 inches after full separation. I feel as if the MPH is decent and the motor was just on the dyno to confirm that it has enough power to go much quicker than what it has. What am I missing? Is there a half second of ET in chassis tuning? Converter? I know everything is not optimum but I feel like with what I have, I should be closer to the ballpark than this. Any help on four link bar adjustments, spring rates, suggestions, etc. would be very helpful. Thanks, JP |
JP,
Betting you are going to hear "more converter" from those with a good amount of knowledge on that type combo... A lot more converter I am guessing. 7" and 7000 is just a guess? Good luck with it. Ken Stock 412 |
As posted above, 7" converter flashing to 7000 - 7100 shifting at about 8600 - 8700. There could be .25 ET or more in the converter.
Once you have the converter then a fine tuning of everything to attain the last bits of performance.
Liked 1,934 Times in 581 Posts
Looser converter and more rear gear. I assume you are using a trans brake. Loosen the valve lash to .035 on the intake. More air in the tires until it spins a bit. Tighten the front shocks.
Mike Pearson 2485 SS |
