Hi guys,
Working on my Fourth Gen Camaro 327/275HP (299 adjusted HP) Q-jet combo. 1.98 Powerglide. 6.00 rear gear. 100 inch circumference radials. Looking to run GT/EA-FA-GA I'm not really looking for a brand recommendation, but I would like to know what converter stall you would like to see for the combo listed above. I know there's a lot more to it than just stall RPM, but I am just curious as to what something like this should call for. While you're at it, how about a recommended 2-step RPM, shift RPM, and fallback RPM after the shift? Sorry I don't have much information on the motor. Nothing crazy fast. Hoping to go .60 under in F trim. Thanks, JP Last edited by JP Schuster; 04-15-2015 at 03:29 PM. |
Liked 121 Times in 11 Posts
You have a PM.
Joe DeMarzo 1317 STK |
Liked 99 Times in 60 Posts
J P, a builder tells me the 327 packages are in the 7" converter range and above 7000 stall [if you have the heads and cam to run about 8600 RPM]
Larry Woodfin 471W |
Sponsor
Liked 59 Times in 12 Posts
Correct, the 7" is the best way to go in the 283-327 S/S combos.
