Guys ,just wondering what everybody is using for synthetic wheel bearing grease.. I race in a pure stock drag class and use a tapered bearing..what brands to you guys recommend....and does it make a difference?thanks for any help or comments.Chris
Liked 55 Times in 28 Posts
Some guys on yellowbullet recommended Lamb:
http://www.lambcomponents.com/misc-p...g-grease-p-199 |
I was given a couple of tubes of synthetic grease that was designed for aircraft wheel bearings operating in the Artic . It was thin !! Ran out and never bothered to look to buy anymore. I now use snowmobile grease. I doubt there is very much to be gained here. ---Trevor
Liked 264 Times in 69 Posts
I use Mobil 1. Don't know if there is anything better. There probably isn't much advantage no matter what you use.
John Dinkel 3295 STK |
Liked 126 Times in 20 Posts
Valvoline SYN Power grease part#W985
Tim Worner SS 1747 |
Liked 6 Times in 2 Posts
When I used to use grease it was Lamb. Haven't used grease since we switched over to Jack's Bearings.
Liked 335 Times in 182 Posts
Most any of the Lithium 220 series greases will work well--Timken/Mobil 1 ETC.
