Liked 1,471 Times in 308 Posts
It's time to replace our flexplate. Are any better than the others in any
way, I.E. initial movement, E.T. or ??. The Canadian Dollar is dropping like a rock, so it's very important we buy the right part once, rather than my normal sequence of buying "right-priced", and then finding out there is better stuff and buying a second one!! Thanks in advance for any meaningful input. J.R. (Smallblock Stocker, 200 Metric.) |
Liked 888 Times in 239 Posts
If you are looking for durability , the Meziere billet wheel is as close to indestructable as you can get ....Yes they are expensive but its the only plate I"ve had that lasted the life of the SFI sticker.
They can repoint the teeth when you get it recerted, comes back like new. If you use a 153 tooth , it weighs in under 6# .
Tom, I just priced that one out after your recommendation, YIKES, it
isn't cheap! I would need to see H.P. or E.T. to make that purchase. Great recommendation though. Thanks, J.R. |
Liked 239 Times in 114 Posts
You can't go wrong with a flexplate from ATI.
Liked 1,987 Times in 599 Posts
We have the Pioneer in two cars. Work great and priced good.
Mike Pearson 2485 SS |
Liked 759 Times in 379 Posts
Thanks everyone, I appreciate the responses. J.R.
#8 | |
Liked 7 Times in 4 Posts
Bob Aceves, 746 E/SA A&M motorsports |
Liked 37 Times in 33 Posts
The Internally Balanced Billet Meziere 168 tooth only weighs 6.3 lbs. I like the "one" piece design.
Like Tom stated: they are pricey, but you get what you pay for. |
